Re: Plate over Rear Gears
Posted by Andy Martin on November 19, 2004 at 08:04:31 from (64.219.39.195):
In Reply to: Re: Plate over Rear Gears posted by Charles Park on November 19, 2004 at 07:49:22:
The top plate is heavy. The shift forks come out with it. If the tractor is outside seal the holes with silicone until you get it fixed because water goes directly into the housing.
You probably won't be able to get the bolts out with a pipe wrench and will probably break more off getting them out.
The easy way is to weld a nut on each broken bolt and take them out. Welding the nut on heats the bolt and breaks the rust seal, freeing up the bolt better than any penetrant. it would be worth hiring a welder to come do this if you don't weld, in my opinion.
Post a Followup
Subject:
