Re: welding Super M exhaust manifold
Posted by captaink on November 19, 2004 at 10:02:29 from (66.115.214.56):
In Reply to: welding Super M exhaust manifold posted by jnewark on November 19, 2004 at 09:46:05:
I would suggest using nickel rod when you weld, that way if you have to file or grind the weld it will be a lot easier. Even though you are running the tractor and keeping the manifold warm (which sounds like a good idea), compared to the temperatures at the point of the weld (I’m presuming here a stick electric welder) the rest of the manifold will be cold. I would recommend following standard welding procedure for cast, short welding time, a lot of peening, and let it cool back to running temp before going on. I would think that running the tractor definitely is a good idea and should shorten the time it will take to weld.
Just my 2 cents…
Post a Followup
Subject:
