Re: Starter is locked in my super A
Posted by John *.?-!.* cub owner on November 20, 2004 at 08:27:28 from (208.54.220.24):
In Reply to: Starter is locked in my super A posted by Charles Houston on November 20, 2004 at 07:32:15:
As Redgreen said, put it in high gear and rock it, if that doesn't help loosen the starter mounting bolts and try again. Starters lock because the bevel on the ends of the teeth of the ring gear or the starter drive becme worn and they lock end to end instead of engaging. If it starts happening regularly the starter drive is easy to replace if it's the problem. If it's the ring gear on the flywheel, then it needs replaced, or it can be repaired by using a Dremel tool through the starter opening to reshape the bevels on the teeth. If you go the Dremel rout there will be 2 places 180 degrees from each other where the teeth are worn due to the engines always stopping between compression strokes.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
