Re: Starter is locked in my super A
Posted by Bus Driver on November 20, 2004 at 09:42:31 from (66.226.37.143):
In Reply to: Starter is locked in my super A posted by Charles Houston on November 20, 2004 at 07:32:15:
When it locks, pulling the tractor forward while in a forward gear will jam the starter drive/flywheel teeth even tighter together. Might cause additional damage. Putting the tractor in the highest forward gear and pulling it backward will unlock it nicely. The easiest (temporary) fix is to loosen the starter bolts enough to wiggle the starter. The drive will retract and the starter can be retightened. No need to disconnect the battery cable.
Post a Followup
Subject:
