Re: 240 won't start -- any thoughts
Posted by old on November 20, 2004 at 11:51:47 from (63.186.48.139):
In Reply to: 240 won't start -- any thoughts posted by Dave D on November 20, 2004 at 11:38:12:
Well since you can't turn it over and check the spark, pull the disb cap off and with one hand and key on hold the coil wire close to the block, etc. With the other hand and a screw driver with a good plastic handle open the points and see if you have spark, if so thats not the problem if no spark you have ignition trouble. Be careful if you goof when trying to open the points it will let you know you have spark the hard way ouch.
Post a Followup
Subject:
