Re: 240 won't start -- any thoughts
Posted by Bob on November 20, 2004 at 12:10:32 from (66.163.134.177):
In Reply to: 240 won't start -- any thoughts posted by Dave D on November 20, 2004 at 11:38:12:
Take a spare spark plug, and bend the gap open to 3/16", and use it as spark tester. Get someone to activate the starter while you watch for spark.
A spark that just jumps a normal plug gap may not be "hot" enough to ignite the pressurized charge in the cylinder.
The idea of manually operating the points is OK, but actually cranking the engine and checking for spark gives you a more accurate idea of how much spark you have under cranking conditions, which lower the battery voltage.
If the spark jumps the 3/16" gap OK, and the engine seems to be getting gas, try removing the spark plugs, and (safely, away from gas and vapors) heating the tips with a propane torch to burn them clean, and reinstall.
Post a Followup
Subject:
