Re: Super H Liftall
Posted by Dave in CT on November 22, 2004 at 12:17:29 from (204.60.45.239):
In Reply to: Super H Liftall posted by Herb in Tx on November 22, 2004 at 08:34:03:
I"ve done a lift-all for a regular '47 H. I bought the smaller IH paper gasket that goes between the pump back plate and that cast that houses the high pressure ports. I made a gasket out of 1/8" (or so) vegetable gasket material for the interface between the pump backing plate and the resevoir. I figured I didn"t know the constitution of the high-pressure gasket so I should buy that one but the backing plate/resevoir gasket is unpressurized. Worked like a charm.
Post a Followup
Subject:
