Re: Super A: Starting Problem
Posted by El Toro on November 22, 2004 at 15:30:42 from (170.224.224.154):
In Reply to: Super A: Starting Problem posted by PaulG on November 22, 2004 at 09:19:40:
Hi Paul, Did the engine start ok before you installed the ignition parts? If it did, I would
check the points again and rub some 400 grit emery
cloth thru them and recheck the gap.
If you're getting good fire you may want to place your hand over the Carburetor throat
to see if you have a vacuum while cranking. Checking the compression will show if the rings
and sleeves are getting worn and valves are seating. Hal
Post a Followup
Subject:
