Re: Water Temp
Posted by Bob M on November 22, 2004 at 16:17:50 from (69.201.120.79):
In Reply to: Water Temp posted by BVB on November 22, 2004 at 09:30:50:
It depends on weather and load. Assuming a 150 deg thermostat is installed, in cold weather and with a light load it'll struggle to reach even 100. However in warm weather and under heavy load you can safely run to 220 or so if you use 50-50 antifreeze and have a pressure cap on the radiator.
Mine seem to run best between about 170 - 200. But like the NB Cowman I gotta use winterfronts to cover the entire grille to get 'em up to this temperature when the weather is below freezing.
Post a Followup
Subject:
