Farmall Tractors Discussion Board
Re: Re: Re: MRear end oil change
Posted by LynMn on November 20, 1999 at 09:32:34 from (216.161.105.84):
In Reply to: Re: Re: MRear end oil change posted by HR on November 20, 1999 at 05:46:55:
HR The grit & chips in the lube troughs is not
loose.Kind of packed in like silt in a road
ditch.Until it is hit with the washing action of
diesel fuel. Then a large quantity of grit is
washed into the ball brgs. I am not predicting
imediate brg. failure, and Iam sure many trans.
have been flushed out without a problem.
I dont recommend it.
Post a Followup
: Re: Re: Re: Re: MRear end oil change
