Re: Farmall 400 or 450
Posted by DWV on November 23, 2004 at 18:29:31 from (205.188.117.13):
In Reply to: Farmall 400 or 450 posted by Dente on November 22, 2004 at 18:02:22:
Im guessing you have a 450,because if it was a 400 with low tractor serial # 3272 as you have the
engine cast # should end with R1 instead of R2.
Look on very bottom of clutch pedal,if it has a bolt with a lock nut on it to limit clutch pedal
travel,its a 400, if not its a 450.Several other ways to tell,but engines get changed more often than clutch pedals.
Post a Followup
Subject:
