Re: Super H Battery Drain
Posted by Bob M on November 24, 2004 at 04:18:07 from (165.170.128.66):
In Reply to: Super H Battery Drain posted by TDK on November 23, 2004 at 20:46:01:
Your alternator has a bad internal regulator. Replacing the regulator should cure the problem.
Note: Some cheap “1 wire” regulators leak a small amount of current thru the alternator even when shut down and will flatten the battery if left idle for very long. Make sure to buy a quality regulator. Or better yet replace the regulator with a 3 wire regulator and wire it up accordingly. (I case you can’t tell I’m not a big fan of 1 wire alternators...)
Post a Followup
Subject:
