Re: starter getting hot!!!!!!
Posted by EricB on November 24, 2004 at 09:27:00 from (216.209.84.11):
In Reply to: starter getting hot!!!!!! posted by mo money on November 24, 2004 at 09:15:44:
Sounds like your starter switch is not disengaging completely. Does you batttery go dead regularly? If the starter switch is remaining in partial contact it will "leak" power through the starter and drain your battery. Try disconnecting the starter when charging, then disconnect when finished working and see if your battery holds a charge better.
Post a Followup
Subject:
