Re: Tractor implements and field plowing
Posted by Novel Idea Guy on November 24, 2004 at 10:40:51 from (64.80.110.40):
In Reply to: Tractor implements and field plowing posted by JBlavl on November 24, 2004 at 10:18:45:
The pile of "rake" teeth in the barn is probably a set of cultivators. These are used to knock down the weeds between rows of corn while it's growing.
There are quite a few different ways to "fit" the field after the plowing is done. A disk harrow is one way. We use a drag (I believe the proper technical term is "spring tooth harrow"). These are generally simple implements that trail behind the tractor, hooked to the drawbar.
Post a Followup
Subject:
