Re: SM blows muffler apart!!!
Posted by gusc on November 24, 2004 at 11:17:34 from (63.97.117.40):
In Reply to: SM blows muffler apart!!! posted by knauffj on November 24, 2004 at 07:25:28:
Backfire is caused by too lean mixtures. The fuel/air charge doesn't explode when it should in the cyl so it explodes in the exhaust.
The starting after releasing the starter can be caused by the same thing.
Also, if you have installed a key start and solenoid you have the starter hooked to the wrong terminal. Some key start switches have a terminal that bypasses the ballast resistor for starting only and if you hook up the starter to the normal run terminal it won't start until you release the starter.
Post a Followup
Subject:
