Re: Timing marks on Farmall H
Posted by ChadS on November 24, 2004 at 11:24:46 from (66.228.96.212):
In Reply to: Timing marks on Farmall H posted by PA Steve on November 24, 2004 at 10:43:28:
If you have the engine torn down far enough to remove the cam, If the head is off, center the #1 piston at top dead center, then, the camshaft timing, there are two marks on the gear, one for the crank, and one for the distributor. Best advice for which timing marker is which, and knowing its correct, is to install #1 lifters in the block, they both should be down, or valves closed, if you have the piston all the way at the top, the cam in the right place, the markers should be darn near close enough to recognize as to where, and which one is which. Look up at where the distributor would mount up, there should be a mark there, and one at the crank. As for the mechanical advance, and timing, follow the book specs on the timing, and make sure the advance mechanism is not stuck, or sticking. If they are, that robs the throttle response from the engine idle to full throttle. Hope this helps a bit. ChadS
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
