Re: Timing marks on Farmall H
Posted by CNKS on November 24, 2004 at 13:26:36 from (207.178.96.213):
In Reply to: Timing marks on Farmall H posted by PA Steve on November 24, 2004 at 10:43:28:
The TDC mark you want on the crankshaft for static timing is the first one (in the direction of crankshaft rotation). The crude way to see if the advance is working is to use a timing light and see if the marks move as you accelerate. The I&T manual says full advance is 40 degrees BTC for a distributer. If you have a mag, the "magneto running timing" is 35 degrees BTC. No rpm is specified, but since the book says "full advance" I suppose if you get that advance at, say, wide open throttle, you are ok. Chad or someone else can explain what I can't. I have never checked anything but the static timing, just quoting the book.
Post a Followup
Subject:
