Re: putting tractor chains on tractor?
Posted by jb2 on November 24, 2004 at 17:59:50 from (24.157.143.220):
In Reply to: putting tractor chains on tractor? posted by wagner on November 24, 2004 at 14:57:56:
Hi, lay the chains out behind the wheels, take some baler twine and thread it thru one of the holes between the hub and the rim making sure it is not near the valve stem. Now tie the baler twine to each side chain and drive forward slowly and the chains will be pulled around the tire.
It works better if you have someone assist by guiding the chians onto the tire but can be done alone by stopping every few feet to make sure chains are aligned properly.
Good luck
JB2
Post a Followup
Subject:
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
