Re: 1939 M Farmall?
Posted by dej(JED) on November 25, 2004 at 15:18:06 from (205.188.117.13):
In Reply to: 1939 M Farmall? posted by JD Farmall on November 25, 2004 at 10:04:46:
You can't really go by casting numbers either.
Many of these tractors have been repaired with parts and even whole sections from donors. I have seen gasoline Ms with MD serial tags. The small tank is an indication of an older tractor. The 39 had a recession in the middle of the deck plate. The motor would be the 247ci engine. The radiator should have shutters and the manifold should have an adjustable flapper. Good luck in your quest.
Post a Followup
Subject:
