Re: putting tractor chains on tractor?
Posted by Hugh MacKay on November 25, 2004 at 16:32:59 from (209.226.247.158):
In Reply to: Re: putting tractor chains on tractor? posted by Tim in NB on November 25, 2004 at 14:19:39:
Tim: Those Norse are a nice wheel chain, everyone speaks highly of them. I bet they don't give them away.
Over the years I've run a lot of chains on tractors, forestry skidders and trucks. Tight chains will not wear as fast, a big item on trucks. We ran them 12 miles into the bush, chains all the way. Wear of course is a big factor with trucks, looking at small diameter wheel and even speeds of 20 mph.
I have seen tractor tires damaged from tight chains. I think even tractor chains will wear better if snug, but you will not get the cleaning action, nor will you get as much traction. I had never heard the thumb rule Norse gave you. Old rule of thumb I heard was put 2x4 on edge under a cross chain. I'm thinking probably not a lot of difference either way.
Post a Followup
Subject:
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
