Posted by LMack on April 03, 2009 at 19:31:17 from (74.176.38.44):
In Reply to: F-20 Fuel Line posted by tritowntb on April 03, 2009 at 15:30:47:
Even on my 200 (1956) and an earlier 1941 B I had trouble using the original fuel line fittings. Both needed fuel lines and I did not find original replacements. I used steel break lines (5/16"). The built in fitting on the break line will bolt up to the aftermarket bowl with no modifications. On the carburetor end, the original used a male compression elbow fitting for the carburetor end and a female coupling on the pipe end above the compression ring. I was not able to find that arrangement but previous post indicate that it is available. Check previous post for Fuel Lines. I just replaced the male elbow on the carburetor with a female and put the male end and the compression ring on the new fuel line. I doubt that you will be able to remove the old compression ring from the old pipe without damaging the pipe.
Today's Featured Article - Women and Tractors - More Views From the Farmer's Wife - by Teri Burkholder. The top ten reasons why the judges wouldn't let you participate in the stock antique tractor pull: Hey, this is stock! It came with that V8 in it! That "R" on my tires stands for "really old" not radial! Blue gas? We thought it was a pretty color! What wire hooked to my throttle?
... [Read Article]
Latest Ad:
[More Ads]
