Re: Farmall M PTO oil seal
Posted by DWV on November 26, 2004 at 17:18:34 from (205.188.117.13):
In Reply to: Re: Farmall M PTO oil seal posted by woodcutter on November 26, 2004 at 14:35:20:
If it was installed at factory the serial # plate would have extra code stamped on it.If you have experience with Ms it would be noticeable
slower than most in first gear.Theres a 99% chance
yours is standard.Don't see many with low low.
Regardless it sound like you have to pull you're
PTO to repair it.When you remove it look at front
of PTO shaft,If it has splines you're 46 will work,if it looks like a big fat screwdriver bit
the later PTO won't work without changing transmission countershaft.
Post a Followup
Subject:
