Farmall Tractors Discussion Board
Re: Re: Re: Re: Re: Engine On M RPMs
Posted by RB HMMMM on November 21, 1999 at 06:29:11 from (206.74.34.112):
In Reply to: Re: Re: Re: Re: Engine On M RPMs posted by T'other Fred on November 20, 1999 at 16:37:00:
Well im not real sure why some manufacturers set certain engines at certain speeds other than delivering the most torque at that speed for a certain application.Seems to me if the same engine could be used in something else at higher rpms why cant a different engine be turned up the same way.Guess they set them there to keep us from riping out the trans or something,like I said earlier Ive seen guys turn up the rpms on there H of M and tear up gears.I know my I-4 has a higher rpm rating on the serial no. plate than a H and those are the same engine.
Post a Followup
: Re: Re: Re: Re: Re: Re: Engine On M RPMs
