Re: Wiring Harness for Super A
Posted by fdew on November 27, 2004 at 16:07:39 from (66.82.9.46):
In Reply to: Wiring Harness for Super A posted by Charles Houston on November 27, 2004 at 07:35:30:
If you go one wire at a time use stranded copper.
Cut out a piece of old wire and take it to a hardware or auto parts store and compare it to new wire to learn the size.
My guess Ignition 14
one light 12
two lights 10
battery As big as you can get. I used heavy duty cables made for trucks when I replaced them
6 volt needs twice the wire that 12 volt does
Post a Followup
Subject:
