Re: IH 574 cuts out when throttle increased
Posted by El Toro on November 28, 2004 at 08:02:11 from (66.119.33.154):
In Reply to: IH 574 cuts out when throttle increased posted by Bucci on November 27, 2004 at 12:19:05:
Hi Paul, If replacing that intake gasket doesn't
solve the problem as TL suggested, I think the engine may be starving for fuel. Are you sure the float level is set high enough? You mentioned that you've choked the engine and it still dies under load. I'd replace that cracked venturi and check the float level.
I had the opposite problem with a car.
It would start and run fine until you stopped and shutoff the engine. Then it wouldn't restart and
I just happen to call the Ford dealer in our area
was talking to their service manager and told him
about the engine flooding. He said Ford had used
floats made from composite material and it would
become gas soaked and then sink. I replaced the float and that solved the problem. My neighbor
had the same problem on a Chrysler and she had it
to every repair shop around here and they never found the problem. I told her that I thought it was the float and she took it back to a shop and they replaced the carburetor. They charged her
$400.00. A float and gasket are around $25.00.
Hal
Post a Followup
Subject:
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
