Re: 966 To Buy or not to buy???
Posted by Duane NC OH on November 28, 2004 at 18:04:18 from (12.34.57.34):
In Reply to: 966 To Buy or not to buy??? posted by Migraine on November 28, 2004 at 07:29:20:
i think that for the price it would be a good deal. i have a 966 that i added a turbo to it. it takes some planning. when we had the engine overhauled the guy doing the work knew my plan and he pulled the crank and had the upper oil passages drilled out. nonturboed engines did'nt have this done. this helps cool the cylinder wall. we also pull on a bigger fan and oil and water pump. bascially 1066 stuff. the exhaust manifold is bigger and uses a bigger muffler. when it was finished it dynoed at 125 hp. and don't forget to put on a pryometer.
good luck!
Duane
Post a Followup
Subject:
