504 oil leak/amp tellite
Posted by Tom/Idaho on November 29, 2004 at 16:41:46 from (12.150.93.248):
First off, thanks to all who assisted with my amp tellite question. I get the generator back tomorrow and will try it out. THANKS!!!
I have a parts picture of the hydraulic draft/lift control and I think the oil is leaking thru the tube assembly (position control) that holds the draft sensitivity control lever. There is an O ring (# 81) in parts picture that goes around the draft rod which is inside the position control shaft. I have removed the outside lever and the three bolts that hold the quadrant to the case and the assembly comes out a bit.....can I remove the quadrant from the case to take the shafts/levers apart to replace the O ring? I am reluctant to try and pull the quadrant away cause I really don't want to remove the transmission cover. Any suggestions will be appreciated. Tom/Idaho
Post a Followup
Subject:
