Re: Farmall M Propane tank questions
Posted by Andy Martin on November 30, 2004 at 05:44:59 from (64.219.39.195):
In Reply to: Re: Farmall M Propane tank questions posted by scottAR on November 29, 2004 at 16:21:08:
It is important to not increase the relief valve setting on a tank above that for which it was designed. At 120 deg F, butane will develop about 55 psig. Propane, however, will develop 225 psig or more. The boiling point of most liquids is dependent on the pressure it is under. That is why pressure cookers work, raising the pressure raises the temperature the water boils at so the food is cooked at a higher temperature, and up in the mountains, with lower pressure, it can be hard to boil an egg because the water boils at a lower temperature. Pure propane will boil at 120 deg F at 255 psig, and will boil at 0 deg F at about 24 psig. At standard atmospheric pressure (15 psig) it will boil as low as -40 deg F. So a propane tank will continue to produce gas down to below -30 and below. Commercial propane is a mixture of propane, butane, ethane, and other gases but is mostly propane. After extended refilling and use, liquids like butane will tend to collect in the bottom because they don't boil as quickly as the propane does. Ethane boils more quickly and won't make a liquid above 80 psig regardless of the pressure. We replaced the level gauge on my 500 gallon propane tank a few years back and found 20 gallons or more liquid in the bottom that did not want to boil off with the tank open. I am saying all this to say when a tank gets very low the presence of material in the tank other than propane will cause the gas coming out to act differnet than propane. So if you have an old tank and it has not been drained in a long time, it may not produce propane until it is dry.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
