Re: has anyone every sand blasted a carb?
Posted by jonesy on November 30, 2004 at 15:52:50 from (64.136.27.225):
In Reply to: has anyone every sand blasted a carb? posted by Chad from MI on November 30, 2004 at 04:50:31:
Bead blasting the carb is the ONLY way to get it truly cleaned and rebiult. You can blast all the parts accept the float. You MUST remove ALL the plugs and then clean each passage with a drill bit and tap or a torch tip cleaner. If you were to send it to a carb shop they blast them every time. They sell cheap blast cabinets on Ebay that work great for carbs.
Post a Followup
Subject:
Today's Featured Article - Product Review: Kreem Brand Fuel Tank Liner - by Staff. This condition has occurred on a few machines that we have had and fortunately we were able to borrow the technique used at the local motorcycle shop. The product that we have used is called Kreem thouh there are others on the market, this one was recommended and available. This particular product is sold in three parts, a bottle of etch, dryer, and sealer. We were fortunate enough to start the process with stern warnings from those that had used this type of product before. The horror ... [Read Article]
