Re: Hydraulic cooler
Posted by Allan in NE on December 01, 2004 at 03:46:53 from (64.187.91.41):
In Reply to: Hydraulic cooler posted by Dick Davis on December 01, 2004 at 03:39:13:
Hi Dick,
An automotive cooler would bge a little enimic, I would think. Although the tranny pressures will run up to around 120psi (in reverse) the lube circuit and cooler pressure is only running at a mere 7lbs; a bit on the low side. Plus the fact that these coolers would be very restrictive in a hydraulic system.
What makes you think it is running overly hot? Normal temps should easily be up there around 200 to 300 degrees, I would think.
Allan
Post a Followup
Subject:
