Re: can i have power steering without hyd outlets?
Posted by Bob M on December 01, 2004 at 04:36:42 from (151.190.254.108):
In Reply to: can i have power steering without hyd outlets? posted by Bryce Andreasen on November 30, 2004 at 19:46:29:
Bryce - I'm wondering if your flow divider isn't messed up or installed wrong. It should work the opposite from what you are seeing under low pump output conditions. I.e. it should cut off pressure to the remote outlets while still providing flow to the steering motor.
Incidentally on the Super M with the live hyd pump-powered Charlynn system, the steering motor is fed via a priority valve (flow divider) in hyd pump output line.
Post a Followup
Subject:
