Re: EARLY H M SEAT SPRING
Posted by John *.?-!.* cub owner on December 01, 2004 at 11:09:10 from (208.54.220.24):
In Reply to: EARLY H M SEAT SPRING posted by IH-JD-FORD on December 01, 2004 at 09:45:11:
What is really a thrill is when the bolt going through it breaks. The nut and spring cap go up past your nose while you are dropping. You can't drop very far, but it sure gets your attention.
Post a Followup
Subject:
