Re: OT, 93 F-350 Diesel problem
Posted by ChadS on December 02, 2004 at 17:44:23 from (66.228.96.210):
In Reply to: Re: OT, 93 F-350 Diesel problem posted by Bob on December 02, 2004 at 15:25:57:
Bob, I found that the plug for the thermal swith, indeed was unhooked. I removed the arm, and messed around with the adjustment screw, I now know what u mean about the sound they make. Makes it rattle! that was backed all the way out. it was holding in the retard plunger in quite a bit before i removed it, I have not put it back on just yet, it rattles bad when it is at full rest, or advance., Ive never heard one run that much to know what sound it should make at idle, especially being naturally aspirated. Im gonna trail and error it for about 5 or 6 test starts, see which sound, it seems to run and like. Found a clamp loose on the return line, off the fuel rail, that goes to the filter, Both timing markers on the pump, and the housing, are lined up straight, thats where the old pump was, so that is where I set this one as well. Ill know more tommorrow heading back out to the garage. Its not too awful cold tonight. THANK YOU again! ChadS
Post a Followup
Subject:
