Re: FARMALL 400D SMOKING
Posted by Haas on December 02, 2004 at 19:09:05 from (12.65.84.111):
In Reply to: FARMALL 400D SMOKING posted by DEWAYNE on December 02, 2004 at 14:22:40:
If your 400 diesel is not shutting off on gas side, I'd say the ignition is not being turned off. Does it have a magneto or battery ignition. If magneto, you have to ground the screw on the side of the mag to shut it off. If there is no wire to that, it is not grounding and will continue to run on gas. Also, the mag should be grounded when you are on the diesel side to stop the sparks to the plugs. That is supposed to happen by itself when you switch the change over gas to diesel lever. Perhaps the linkage that works that has been disconnected or is not working for some reaon. If battery ignition, voltage to the coil has to be shut off to stop the tractor on the gas side. I suspect though that you have a mag, for it the battery ignition was on all the time, you would for sure have a dead battery. If you are getting black smoke, that is carb running too rich, which would be controlled by the choke. If you are getting diesel fuel into the cylinders while running on gas, you will get white smoke, which is unburned diesel. One way you can check also, is does the tractor stop when you just push the speed control lever to the shut off position without pulling the switch over lever to the gas side. If it does not stop when you do that, then something may be out of adjustment in the injection system.
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
