Re: Distributor Woes
Posted by ChadS on December 05, 2004 at 05:54:54 from (66.228.96.168):
In Reply to: Distributor Woes posted by MagMan on December 04, 2004 at 17:26:28:
magMan, is it a delco, or IH? Seeing the springs, Im betting on IH, Is it a vertical distirbutor, or a horizonal mounted distributor? You may check to see if the advance limit pin is in the hole in the plate, sometimes, the rotor shaft will float upwards ,and fall out of the plate. it will explode the wieghts by having no stop to limit, the amount of travel inthe advance. Any IH distributor will fit, provided it is from the same, vertical mounted distributors, were usually delcos,,, and have a different drive gear on the shaft,, so keep an eye out for that if u get another one,, What do you need? Got quite a few laying around, Hope this helps why it does that,, dont know if that is what happened to yours,, ChadS
Post a Followup
Subject:
Today's Featured Article - A Lifetime of Farm Machinery - by Joe Michaels. I am a mechanical engineer by profession, specializing in powerplant work. I worked as a machinist and engine erector, with time spent overseas. I have always had a love for machinery, and an appreciation for farming and farm machinery. I was born and raised in Brooklyn, New York. Not a place one would associate with farms or farm machinery. I credit my parents for instilling a lot of good values, a respect for learning, a knowledge of various skills and a little knowledge of farming in me, amo ... [Read Article]
