Re: Value of a super H?
Posted by CNKS on December 05, 2004 at 18:09:47 from (207.178.96.213):
In Reply to: Re: Value of a super H? posted by Kevin on December 05, 2004 at 17:56:44:
TO get a Super HTA, you have to have the rear of a 300/350 from the engine back. It may not be impossible, but it is certainly infeasible to put a TA in a Super H. The chassis serial on a Super H will have an SH prefix, the engine will have C164 cast on the rear of the block on the right side. It will have disk brakes (cast iron housing, not stamped) as did the last few hundred H's (five bolts holdinge the cover on). The choke rod and lever on the SH carb is behind the carb next to the block rather than in the front. The grille will have IH on it rather than Farmall (grilles interchange). There are other changes too numerous to mention.
Post a Followup
Subject:
