Re: Building a shop
Posted by Pete L on December 06, 2004 at 08:48:13 from (198.36.89.4):
In Reply to: Building a shop posted by Paul Shuler on December 03, 2004 at 14:36:06:
Couple items:
1) Route most of the outlets thru a heavy switch that is mounted out of the reach of your kids, or put a lockable cover over it. Flipping this switch as you leave will make sure all of your machines can be accidently turned on by the kids. Might have to incorporate a 220V relay if you have 22O V needs.
2) While dragging power out there, pull a phone line and also 2 wires to work a buzzer. That way, your wife can buzz you, then pick up a phone to talk to her.
3) Mount outlets 50" off the floor. That way, sheets of plywood leaning against the wall won't get in the way.
4) Outlets cost approximately $1 in parts. Put them every 4' in the area of any machines.
5) Outlets & lights need to be on seprate circuts so when breakers blow, you're not in the dark.
6) Think about an exhaust fan up high to rid heat/fumes/smoke.
7) Windows up high let in light, but are not a major security issue.
8) Thinking about a bridge or stiff-leg hoist at some point?
9) Think about storage trusses. Can gain a lot of off season storage floor space for the bulky lawn chairs, bikes & such.
Good luck. Build safely.
Post a Followup
Subject:
