Re: IH 240 info needed
Posted by Dave D on December 06, 2004 at 13:50:09 from (4.233.158.209):
In Reply to: IH 240 info needed posted by Jrry on December 06, 2004 at 12:02:56:
Jrry, what's the make of your loader? I have a 'Superior' loader
on my 240 and the loader filler plug is on top of a tubular frame
brace that angles down past the engine from high on the right
side near the loader arm pivot. I added about 6 qts the other
day until I could see the fluid at the bottom of the filler hole. I
just used a generic Hydraulic-Transmission oil, rated for IH-
Case and other major manufacturers, sold at Sam's Club in 5-gal
pails. It seems to work fine.
Post a Followup
Subject:
