Re: IH 240 info needed
Posted by Migraine on December 06, 2004 at 15:01:20 from (24.18.75.6):
In Reply to: IH 240 info needed posted by Jrry on December 06, 2004 at 12:02:56:
The transmission and hydraulic system all use a common fluid (hy-tran) held in reserve in the rear end housing, There is a check plug on the left side of chassis in front of the clutch that takes a 9/16 wrench to open. The system should take app. 12 gallons to fill. If you are just topping off take the plug out add a gallon with a catch can below and add till it runs out the plug. Migraine
Post a Followup
Subject:
