Re: SC Belt Pulley Drive Shims
Posted by wayne in mn on April 03, 2009 at 21:12:21 from (68.190.102.179):
In Reply to: SC Belt Pulley Drive Shims posted by LMack on April 03, 2009 at 19:17:57:
None needed if the shims are clean. I have put a VERY thin coat of silicone sealer on each shim and re-assembled.
