Re: 504 Background Info Wanted
Posted by Joe Evans on December 07, 2004 at 06:20:02 from (209.41.233.20):
In Reply to: 504 Background Info Wanted posted by Glenn FitzGerald on December 06, 2004 at 21:11:31:
The 504 belongs to the -06 family--806, 706, etc. The 504 and its little brother, the 404, appeared in 1961 two years earlier than the bigger tractors (1963), so there is some crossover between series breaks. The -60 series came just before the -06 series with their production ending in 1963.
We have both a 504 and 460. While close in HP ratings and sharing a lot with respect to rear ends and axles, a 504 ain't a 460--153 CID @ 2200 RPM vs. 221 CID @ 1800 RPM
It is a niche tractor as Sloroll said and was intended, I think, as a chore tractor--hay raking, cultivation, loader work, etc.
Post a Followup
Subject:
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
