Re: 1948 Cub final drive.
Posted by banjo on April 03, 2009 at 21:18:28 from (65.67.203.13):
In Reply to: 1948 Cub final drive. posted by Mike Franks on April 03, 2009 at 19:35:35:
the bearings are pressed on.they can be pretty tight. make sure you have all the bolts out of both sides. once you get the shaft off the inside bearing it should come on out. But you will still have to pull the outer bearing once the shaft is out.
