Re: IH 240 info needed
Posted by mowr on December 07, 2004 at 07:56:46 from (67.96.2.134):
In Reply to: IH 240 info needed posted by Jrry on December 06, 2004 at 12:02:56:
If you're referring to the 240 built 1958-1962, the Hydra-Touch system has its own reservoir independent of the transmission fluid. The filler plug is at the upper left side of the torque tube casting (where it narrows down from the clutch housing). The drain plug is at the lower right side of the torque tube. This is the way mine was and I just now double-checked the owner's manual to refresh my memory.
Post a Followup
Subject:
