Re: need help timing counter rotating gears on cra
Posted by Bernard le mécano on December 07, 2004 at 09:00:58 from (207.134.181.9):
In Reply to: need help timing counter rotating gears on cranksh posted by Ian Davies on December 06, 2004 at 16:53:11:
Hi Ian, place the cylinder 2 on tdc and you can see a punch mark on crankshaft gear. It have 2 punch marks on one gear of the balencer housing for timing with the crankshaft gear. Normally when the 2 piston is on top, you put the housing in place ( counter weights in down position) and it,s ok. Don't start engine with out timing of the balencer or the housing will be broken by shaking. Also, put new O rings for the lube. Check the lube pressure after the job, if it low, may be the cam bushings have to much clearance. The low lube pressure will worn the balencer.
Bernard le mécano Québec Canada
Post a Followup
Subject:
Today's Featured Article - A Lifetime of Farm Machinery - by Joe Michaels. I am a mechanical engineer by profession, specializing in powerplant work. I worked as a machinist and engine erector, with time spent overseas. I have always had a love for machinery, and an appreciation for farming and farm machinery. I was born and raised in Brooklyn, New York. Not a place one would associate with farms or farm machinery. I credit my parents for instilling a lot of good values, a respect for learning, a knowledge of various skills and a little knowledge of farming in me, amo ... [Read Article]
