Re: 504 Background Info Wanted
Posted by Mike S 806/H on December 07, 2004 at 14:45:32 from (66.188.1.154):
In Reply to: Re: 504 Background Info Wanted posted by Nebraska Cowman on December 07, 2004 at 05:17:15:
The 504 has the same bore and stroke as a Farmall H but alot more rpm"s. Power comes from the rpm"s and gear the pto down to get 46 hp. I have a 504 engine in a C and BN the BN on the dyno did 28hp but the pto was turning 950,
Post a Followup
Subject:
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
