Re: 12V warning light
Posted by gusc on December 07, 2004 at 14:59:53 from (63.97.117.41):
In Reply to: Re: 12V warning light posted by little john on December 07, 2004 at 12:05:38:
LJ,
The answer is, yes.
I had this happen to me once when I removed all the idiot lights from my '74 GMC one ton and added gages. It took a lot of wiring diagram studying before I figured out what was happening. It usually took three or four days to discharge because the current drain is very small.
As the others have said, there must be a diode (which is just a one way switch), a dedicated switch or a light in the circuit.
Post a Followup
Subject:
