Re: 1951 Farmall H Transmission Noise.
Posted by ChadS on December 07, 2004 at 19:44:59 from (66.228.96.214):
In Reply to: Re: 1951 Farmall H Transmission Noise. posted by farmallhal on December 07, 2004 at 18:18:48:
Check the drive shaft coupler bolts, there is rubber washers that will wear out and make the shaft loose and rattle, you will have to drop the pump inspection plate to check them,, will sound like a bearing too! ChadS
Post a Followup
Subject:
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
