Re: Super A running on only 3 cylinders.
Posted by captaink on December 09, 2004 at 07:28:47 from (66.115.214.56):
In Reply to: Super A running on only 3 cylinders. posted by Brian in Toronto, Ontario on December 09, 2004 at 07:17:46:
Are the spark plug wires solid wire or carbon? How old are they? I would suggest taking a compression check on the engine. All cylinders should be within plus or minus 10%. If they are, I would replace the cap, rotor, spark plugs, and spark plug wires. I suggest solid wire spark plug wires. If not, you probably have a leaking valve and will need to pull the head to correct the problem.
If you have a bad spark plug wire, that resistance can lead to arcing in the cap causing a carbon trail to another cap terminal. Then the spark follows that trail to the wrong cylinder, causing the miss.
Good Luck
Post a Followup
Subject:
