Re: Super A running on only 3 cylinders.
Posted by Haas on December 09, 2004 at 13:36:03 from (12.65.18.97):
In Reply to: Super A running on only 3 cylinders. posted by Brian in Toronto, Ontario on December 09, 2004 at 07:17:46:
If you have a hand crank, you can check for compression by putting tractor in neutral (leave the ignition off) and insert crank and turn engine two full turns. If all is OK, you should feel about equal resistance (compression) on each half turn. If not, then you probably have a stuck or burned valve. If it checks out, then I'd change out the plugs.
Post a Followup
Subject:
