Re: Timing advance springs in distributor - don't
Posted by Bob on December 10, 2004 at 07:52:05 from (66.163.134.177):
In Reply to: Timing advance springs in distributor - don't matc posted by Bradford253 on December 10, 2004 at 07:45:32:
If the engine "kills" as the throttle is pulled back, you likely have a carburetor problem, and when the fuel flow in the carburetor needs to switch from the "HIGH SPEED or LOAD" circuit to the idle circuit it's starving for gas.
As far as the advance springs, I cannot speak specifically for your tractor, but on various distributors, it is NOT UNCOMMON for the springs NOT to be matched.
This use of unmatched springs is a way for the manufacturer to "tweak" the advance curve to the exact spec's they want.
Post a Followup
Subject:
